1/144th Prometheus scratch build
Glad to see your 'construction site' got organized.
Your work at there makes my works look like a micky mouse thing.
Take good care of your hands and it shuold be the first priority.
All the best,
katsu
One of my favorite all time ships! This is going to be epic when you get finished! How are you going to handle the cockpit etc/all the windows? Obviously you are going to light the beast!?
Nice work cleaning your "atelier"...I see that these engines are going to be slightly complicated, but you're off to a good start;)
Evenin All,
Thanks for stopping by everyone
Lot's to get on with so less chit chat
Glued the middle section of the engine together ready for shaping
Shaping on my little 1" belt sander
Then on with the ******* half round
Finished with a fine sanding board
Filled and ready for sanding later
Then it was on to the central 4" tube, marked one out.
Rough cut with a disc in my dremel
Dry fit with everything
Then the center piece was sanded
Ready form primer, mmmmmmmmmmmmm
Also filled sanded and primered the nozzle section
Then i finished the internal support by hand with files
Then i did a second one
3 and 4 were together
Now i'm concentrating on the inside structure of each engine.
So stay tuned
Gag
