1/144th Prometheus scratch build
Looking good, besides the surform tool. Maybe a little less hardener in the bondo. Which will give you a little more working time to smooth it out. I know here in the summer ill stick the can in my old fridge for 30 minutes. Cools it down gives me more working time here in the heat . The smoother the bondo easier it is to sand and get the shape you want.
I thought, if there would be a guy who can build this model, it would be Al the IEDBOUNTYHUNTER or NylonGag for sure.
Al-san has enough knowledge, experiences and technique, and Gag-san does too.
This will be another legendary model like Al-san's Betty.
All the best, Katsu
Evenin All,
Thanks for stopping by and commenting
Got me one of those yella thingeez, thanks for the tip
Soooooooooooo, enough chit chat
Gave the top its first basic sanding
Did the same on the bottom but it didn't turn out as good as the top
Evened up the back
And the front
Cut and drilled the inner edge of the outer engine arms, then lag screwed these to the main assembly to mark out for cutting
Cut them out
Attached the inner arm supports
This is everything so far
Well, injested enough bondo dust for one day
Take care
See you soon
Gag
Subscribed!
You're doing such a smashing job, keep it up!
P.S. I have a copy of "Art of Prometheus" it's yours if you want it, just PM me your address (call it a pay it forward/ Christmas gift)
You are just too generous my friend, thank you so much.
PM sent
When an engineer builds a model, magic happens! :)
Ello mate, thanks for the kind words
Starting to see the overall shape of that model. Eager to see the next update:)
Glad you can see it mate, cuz i ain't got a clue what i'm doing
Awesomeeeeeeeeeeeeeeeeeeeeeeeeeeee!!!
Thaaaaaaaaaaaaaannnnnnnnnnnxxxxxxxxx
Well, ere we go folks,
welcome,
hold on tight for a fast ride,
the louder you screem the faster we go.............
Marked,
cut,
assembled and attached,
the basic outer profile of the side engine supports.
1/8" styrene sheet.
Chiselled away witth my shaping/scraping tool,
More plastic sheet,
More shaping/scraping,
Marked me radussssssses,
Cut with 6 flute carbide 1/8" , high helix end mill in me dremmel on top speed, knife, butter, etc ........
Radiusedid bottom edge,
Assembled,
https://lh5.googleusercontent.com/-
m7vS61r1QSg/VITssevbHDI/AAAAAAAASbY/TznB9zI3Kvs/s800/stuff%2520314.jpg
Added inner strip to support bottom surfaces
But that's for next time
Thanks for stopping by.
It means alot .
Gag
Really looking forward to any update. This thread (aka all your threads) are 100% education, inspiration & entertainment!
Ok.... here you are...whew ...!
I was jonesin' there for a bit....
Hope you had a great holiday Gag
Looking forward to following this
Cheers
Merry New Year,
Welcome everyone to 2015, I hope everybody had a fun and safe Christmas and New Years holiday and I wish you all the best for the coming year.
Thanks for the comments guys, much appreciated.
Yes Wibble i have seen them but thanks for the thought
Is that a Multistrada over by the monitor?
No, It's a Hypermotard 1098S, my bike of choice, my wife just got a Monster 796.
So too business,
Well, I only had two days of bench time over the holidays because my Mommy was visiting.
First, I cut the central pipe/bearing shaft and drilled holes in the outer panels of the engine support arms, this was so I could re-align and square up a bit, the side support arms. I will clean the pipe end flush later.
I then cut and glued a piece of 1/8" styrene to the bottom of the engine support arm,
1.0mm on the top, oversized so it could be trimmed back,
Trimmed,
Replaced the underside of the neck piece with 1mm styrene,
Screwed in place,
With engine support arms,
More filling and sanding and filling and sanding........
Then, dum dum daaaaa,............Primer
Mmmmmmmmmmmmmmmmmmmmmm Primer
That's all for now
Take care
Gag
I can't even imagine the stones one must have to start something like this!
Wow x 100000!
