1/144th Prometheus scratch build
So glad you found back fully glory after the cool lille Shuttle!
Nice detailing as expected from you. I keep being stunned you make four of each though you're able to cast and for sure get several questions to cast for others. I line how you use stock track wheels, track links and default profiles to get that busy look.
Glad that project is back on tracks! As Vacformedhero said: cannot wait to see those pieces sprayed into a nice grey.
More great pics. And love that shuttle. You were just a bit too far to see a launch huh. One nice thing about living in Orlando.
Ello my Peeps
Thank you all so much for stopping by and commenting.
It really does mean a lot to me, had some demons to deal with the last few weeks with regards to my wrist issue and everyones support helps me struggle through the pain barrier.
But, have to be honest, making four of everything is beginning to get get on my breasticles a bit.
Why haven't i cast more stuff, well it just don't look good enough to me, and if I'm gunna take all this time i want to be happy with my own methods.
Tried the casting route with one piece early on and i wasted a lot of silicone and plastic because it was easier and better to make four originals.
You live and learn.
I will be casting again in the future i'm sure.
But, enough chit chat.
PIX
What I've done doesn't look like much but its all X4
Did the four internal details on the nozzles
Four ready for primer
Mmmmmmmmmmmmmmm
Then i needed to get all the main body's to the same level so there was lots of fiddling and swapping bits around to achieve the best fits
The white bit is half a truck wheel
Here's a group photo of everyone together all at the same stage
Had to do a quick dry fit test on the main body
Thats about it so far.
Obviously still got a looooooooooong way to go.
Not sure what to tackle next
I will be doing some vac forming i think, need to make a vac former so stay tuned for that doozie.
I'm just making it up as i go along, never vac formed before but how hard can it be, right……………….right, guys, hello
Guys
Gag
out
Gag san,
Fantastic \(^_^)/ I even love before primer.
I did a vac forming sometimes before.
No sweat, you will get used to it soon.
Me? Naaaaa
Katsu
Ps Ihave a knee problem. Im taking condroitin pils.
Take care
Great work as usual. Very inspiring.
I'm also building a vacuum former. I can't wait to see your approach.
Great work,Gag... as always. you make it look so easy. (I know that is a bit cliche but you are a very good modeler) Keep the fire burning, my friend. NO RETREAT! NO SURRENDER!!! :)
Beautiful update Gag and yes, building one or two similar pieces seems a lot (specially with this amount of details) I understand your pain (same thing with my 2001 Space Station)
Keep on building it's looking the bomb!
Inspiring as usual Gag ! Fantastic accuracy and attention to the details...details are what truly make the difference !
It's funny, as soon as I saw that test fit picture and the shear SIZE of this piece, I was instantly taken to that moment from Titanic....:lol
You've definitely helped me to get better with (and during) each one of my projects....
Pcoz
Been a while.
Thanks for sticking with me guys.
Life gets in the way sometimes
Hand and wrist have sucked SO bad the last 3 months
Dislocated my shoulder in my sleep, it takes a special talent to do that, it's probably a super power?
4 hours in emergency at 1am, that was fun.
But, i will survive, good title for a song that.
Plus……..
This scratch building really takes a long time man, especially when you have to make 8 of everything.
Mold it i hear you cry.
Would if i could but, i can't.
Anyhoo, less whinging, more modeling
Sooooooooo,
Last time i said i needed to make a VacForming table……………..
Drawdeid it
Cut, drilledeid and dry fit it,
Stuck in me Vac adaptor
Used silicone bathroom sealer like glue before i final fit them, used extra along the inside seams just to make sure to seal all edges
Drilled the top plate
Counter sunk the back face to give better air flow
SilliGlued the top and screwed it down
Hardware
45 ed the ends, drilled and countersunk the angle
Screwed it up x2
Got me some clips and i'm ready to go…………………but
I haven't had enough time to test it yet.
I know
I know
Soooooooon
I got this concept from these wonderful people at Punished props, so props to them
I did re-do my first thing to be vacced though, the side dome
Re-filled it, re-sanded, re-apoxied, re-sanded it and then re-primed it
Ready to go
Started the movable flaps on the engines
Cut from a thermal cup package to get the curve i wanted
Drew to scale on paper, cut out 8 layers of paper, double side, on the tube bish bash bosh
Cut a slot and entry keyway with me dremel
Used square tube, solid bar and round tube to make the internal structure of the flaps
Currently half way through attaching the inner face of the flap in 1mm sheet on the 8 main assemblies
And that's it so far
I might be vac forming this weekend so stay tuned, might even do a proper video.
Cheers
Gagsterman
Gag-san!! NIce to see you back on.
Looks like you had a hard time being you.
You are a genius modeler, why don't you fix your arm by yourself, brother.
Should be better than any other clumsy docs.
Anyway, it's the great news that you back to build that beast again.
Just take your time and take care. We can wait.:thumbsup
Here's my first vac form things.:D
Looking forward to see you losing some sheet plastic.:p
Katsu
