Yavin 4 scanner (ANH) - all major parts positively identified
Physically or digitally? You could probably replicate it with leather textured ABS sheet or if you mean digitally i can make you a height map of that texture to displace onto the mesh.
I'm trying to apply some digital texture on the 3D files, so when they are printed, it's already on them.
I've attached a tileable heightmap created from a photo of the Minolta Auto Spot 1. Below is what it looks like displaced onto a plane. The other texture could probably be done with your standard noise texture.
OK, let's call it a day. I've given up on making those surface texture due to lack of tools. Anyone who know how to do it, please PM me, so I can send you the unmerged files for further edit.
With Dart's help, I've made the basic dimension as accurate as possible, but not down to every single screws.
Right now, it's printable. Just try it.
https://www.thingiverse.com/thing:7094073
If you use blender; a displacement modifier, projecting the texture against the object normals using a vertex group you should get the desired effect. Better would be to use zbrush as it's made for applying texture like that.
I was trying to use blender, but perhaps my PC is too low or not setting it correctly, so it cannot start at all.
