Tron Legacy Costume
I have a question about EL sheets, tape, wire - let's just say EL, in general:
Last Halloween I was a variation of Kevin Flynn, mixing elements of his costume from 'Betrayal' and 'Legacy'. I was very satisfied with the end result (couldn't have done it without the help of MisterDigital, SoulInertia, and SneakyDerezzer). The only problem: I chickened out and didn't use electroluminescence. Instead, I used white reflective tape. As you can see from the pictures, it looks OKAY, but I want to actually finish it with EL.
Here's how the costume looked last year:
I want to retain the shapes on the boots, but I have no experience with EL. What I want to know is: 1.) Which kind should I buy? and 2.) How do I cut the patterns without damaging the lighting in any way?
Thanks in advance!
Thanks in advance!
Hi there TodRaynard43
Love your interpretation on Flynn :cool
What you need is a cuttable EL sheet like this
Scissors or craft knife is fine for cutting the el sheet, whatever your more comfortable with. As long as there is one of each tab on the piece you have cut, it'll work fine. You can choose any two tabs from around the edge (one dark one light), they don't actually have to be next to each other to work.
The el sheets range in price and size depending on who you go to, so it's worth looking around to find one that's suitable, but I reckon you could get both boot patterns from an A4 piece with some left over to play around with.
One trick I use is to draw the tabs on a piece of paper and work out my patterns and which tabs I'll use for the circuite on that first.
Shoot me a pm if you need long explanations, and I'll help you out of needed :thumbsup
Yeah! I tried to post that in the "Tron Lives" group on Facebook, but some fellow got angry so I deleted it. I'm happy someone else is excited for it! They almost have their 500 signatures needed. This could happen. C:
Already? Cool as!
Could anyone recommend a good EL sheet supplier for Australia? Most I've seen are only for the UK and the US.
You are fantastic, Canobi! Thank you so much!
Hey, no prob :)
For those of you with little or no soldering experiance, buy something called Wire Glue (I get mine from eBay). It's a carbon based adhesive that's conductive when cured. It's a little bit brittle once dry, so I use an apoxy resin as a coating to give it strength.
As far as I know, cuttable el sheets come with protruding wires at points around the edge, or take the toothed connector/staple method, it just depends on the supplier. Ask them for as much info on thier product as you need to help you decide whether it's suitable to your skills, but don't be afraid to try something new as there are plenty of great folks on this site that can give you tips and pointers to help you on your way to make a great costume or prop :thumbsup
Yeah us Aussies need better info on suppliers we tend to get over charged here.
Not sure I should say this but, I get some of my larger batches from china (here it comes :behave), it's way cheeper. There are upsides and downsides to this rout. Shipping is always quite expencive for me, and it takes a long time to get here. Depending on your skill level you can ask for the protective layer to be left off so you can make the connections yourself, I to add the layer as a requirement to one order and some of the el tape didn't have it. This did however prove usefull since I have now learned how to make better connections and other useful techniques. I also happen to be quite handy with a soldering iron and was a surface mount repair technician for a few years so wasn't averse to experimenting.
Forgot to mention this
With all el products, there are two rules that need to be observed......
1. Make sure you either laminate or seal the exposed layers/connections that will carry the electric current. Clear Sellotape will work as a cheep edging for el tape and cut shapes, but will go yellow over time due to UV in daylight. Electrical tape is the next best, and for the pro... Laminate or PlastiDip the edges (mask and spray on or paint on works great as its a rubber so will flex just fine).
The jolt from a 9v supply is surprisingly vicious I discovered whilest experimenting, I won't be making that mistake again in a hurry.
2. Make sure the el product is connected to the inverter BEFORE you turn it on. The inverters depend on the el drawing the current to work correctly. With out the el there, it's receiving too much and burns itself out.
I've managed to kill a few in just such a fashion by not paying attention (seves me right though:lol)
Thanks in advance!
Tod,
My advice to you for the strip on your jacket is check out glowhut.com
The strips they sell are the perfect width for a screen accurate look.
That's where I got mine for my Flynn jacket, and it's super easy to cut
and reconnect if needed. Then you would just have to find some sort of
inverter. I found the 9v sized inverters work perfect for this as they fit into
the inside pocket of a jacket very well without noticeable bulging.
To retain the shapes you had on your boots may be a little tricky to attain with just using a straight strip. You maybe have to look into cutable el sheets. I've become quite the expert with the cutable sheets, so if that's the route you think you might go, let me know because I know a great site to get it and would be happy to give you advice.
I was a complete and total noob when I joined this site. Everyone on this thread helped me find the right tools for the job. So ask anything and you will get great advice, as you've already seen from other users' posts!
Hey guys,
I'm working on a new LED aqua disc color to match the Glow of the electroluminescent tape and wire. The color is achieved with a mix of blue and green diodes. Just thought I'd share.
Whoa... that looks awesome! I'll have to order my next Rinzler discs from you when I work on version two of the costume. I love how bright these are!
Just wanted to thank the RPF Tron Thread for helping me find the ideas and materials put my costume together. I put this together last year for Norwescon and it was a smash hit.
@Corren: Whoa! Very clever take on a Tron based costume. I love it the hat and the tie. I also like that you can see the lighting on the vest through the coat. Did you plan that purposefully? I bet you were a hit. This is awesome!
I've been lurking around the RPF for a while now, and after seeing all the amazing things you guys have done I've decided to start on some projects of my own, one of them being the Tron Anon costume. I'm new to the prop scene so I went with a paper craft for the helmet as the pep file was available. Here's some picture of my progress so far. I plan on making a mold and casting it when my order gets here. As for the suit, I'd like to try making it out of foam if possible. This costume is actually being made for a friend of mine and he's almost 7ft tall, so I have my hands full with the suit after I get this helmet done ha.
I'm also working on the Daft Punk helmets. I have more stuff posted at here for those interested.
paper craft model
Tron Anon_Helmet_005 by Detravoid, on Flickr
laying in the fiberglass cloth
Tron Anon_Helmet_011 by Detravoid, on Flickr
adding the fiberglass resin to the cloth
Tron Anon_Helmet_013 by Detravoid, on Flickr
finished resin layer
Tron Anon_Helmet_015 by Detravoid, on Flickr
first coat of bondo
Tron Anon_Helmet_022 by Detravoid, on Flickr
first sand down
Tron Anon_Helmet_031 by Detravoid, on Flickr
after several filling and sanding stages
Tron Anon_Helmet_053 by Detravoid, on Flickr
2-3 layers of primer filler
Tron Anon_Helmet_059 by Detravoid, on Flickr
final layer of gray primer
Tron Anon_Helmet_065 by Detravoid, on Flickr
titanium metallic finish
Tron Anon_Helmet_083 by Detravoid, on Flickr
