Interest The Expanse - MCRN pistol - machined aluminium conversion kit
modeled the bottom front part for the second version of the pistol too as I guess I'm not going to skip it!
bumping this for interest! would be awesome to get a few more people on board to make this worthwhile :)
Interesting that they opted not to attach it using the accessory rail. I'm guessing it's just glued in place?
Great work! I happened to be doing searches on The Expanse pistols and came across this thread.
I am definitely interested in the MCRN pistol
Thank you, very low interest on this, but I'm going to start slowly on it next week when I receive my aluminium order.
I'll be working on my jedi training remote boxes and this, so it will take a little while, but this is happening.
Thank you to those that signed up, much appreciated.
Cheers
What is the availability of the base pistol? I am looking for a "WE X Series IPSC" airsoft and not finding much in-stock at least in the US.
I only have a link in Europe. Maybe someone else can help you in the US.
I was unable to locate one in the US. Also the HK maker was sold out, IIRC... I was able to find them from a retailer in Canada, but their site said they would not ship outside of their country. Still, if you know someone there who can receive it and send it along to you, that should be doable. I ended up ordering mine from Safara Softair in Italy, which worked out fine other than being a bit pricey.
Hi there,
here is some progress for this project, I cut an additional 2 pieces after receiving my aluminium order yesterday, and i drilled all 8 pieces with that dreaded 16mm diameter hole, 12cm deep. that's a good difficult step done already :)
Hi there,
Thanks for the progress photo! It will be fun to see these in-process so I can appreciate the work I don't have to do myself! I'm thinking that drilling a 16mm hole in these would be an "interesting" challenge with my cheap little drill press! o_O
Yeah, I turned this every direction when prototyping. My mill would have made quick job of this but is too low for the needed length, the drill press I don't trust for this, so I had to do it on the lathe, but it takes a lot of time. It is mostly done now, need to do the other side but the hardest part is done :)
