So, I took some of that thick plastruct, maybe 2.5 mm or like 1/8 American and used an old black and decker bandsaw to roughly cut the shape. More specifically…
I used an inside caliper, like a compass with outward facing prongs to get the diameter of the ridges these pieces sit in. Then I divided that by two and set a compass to that radius. I scratched the circle in and traced it in fine sharpie. That was enough to go to the bandsaw.
I then drilled a little hole for a screw where the center hole was, and put it on my mini lathe. I used some needle files to clean up the edges…
I kinda messed up trying to JB weld these things in the cone sections, and thought I was blocking drilling the vent holes for a second, quickly drilled them, and realized I had nothing to worry about anyway. It was a weird evening.
Today I wired up a cool harness. The original RS lamps are like 12v neon tubes, so I took that out and I’m going to put 3v LEDs in there instead. (Thank you Poikilotherm for alerting me) so I grabbed my soldering station, some old wires I saved from some scanning electron microscope equipment, and made a circuit! I don’t have a lot of quick connectors so I made Y connections
And either because of the resistance between the LEDs or how they came, one is a hair slower than the other or something! Makes the effect more interesting.
