Stranger things
  1. That newspaper is from s03e05-06 hospital scenes, real size ((43.18x58.42cm))
  2. Lifeguards pics and letters from s03e03 23m
  3. "Meet Your 85" letters sized for A4 paper
  4. Lightning Warning/Senior Swim Classes/Swim Team Tryouts (times are 100% guesstimation) are all in half letter size paper ((8.5" x 5.5"))
  5. Pool Closures are in half letter size but its in landscape mode (((5.5" x 8.5"))
  6. Hopper and Joyce pic was a gift from xakerofxanthi, thank you again <3
  7. Some random posters from Mike's and Dustin's (need to be "recolorized") bedroom
Im still waiting for your russian envelope to share here RafalFett , sorry taking so long
Thanks for the shares.
No problem, I have patience.
Some new shares today! Drawings made by Hopper's daughters Sarah and 11.
Sarah's Drawing from Season 1, Episode 1:
I think I may redo this one using colored pencil. I kept going back and forth on what to do it in.
11's Drawing from Season 1, Episode 5:
11's Drawing from Season 4, Episode 5:
I think I'll probably give this one another go too at some point (to fix the details on the cubes).
Enjoy!
Enjoy!
Awesome job, as always!
Thanks to ribeiroorafael and his friend (who scanned the files), I can now add the Secret Russian Content to my Doctor Collector Box:
20240527_193555.jpg 20240527_193608.jpg 20240527_193619.jpg 20240527_193731.jpg 20240527_193759.jpg 20240527_193833.jpg 20240527_193848.jpg 20240527_193900.jpg 20240527_193914.jpg 20240527_193923.jpg 20240527_193933.jpg 20240527_193941.jpg 20240527_193953.jpg 20240527_194001.jpg 20240527_194019.jpg 20240527_194024.jpg 20240527_194031.jpg 20240527_194035.jpg 20240527_194312.jpg 20240527_194314.jpg 20240527_194316.jpg 20240527_194318.jpg 20240527_194320.jpg
And here are the files slightly cleaned up (mostly the envelope and Yuri's pilot card) and the Key Blueprint stitched together:
The envelope should be printed on a thicker paper (around 150-180 gr); the flat file measures 262 x 424 mm, while fully closed is 232 x 172 mm. The second file have some extra flaps and can be printed on 3 pages of A4 or LTR paper.
Yuri's Pilot Card Cover.png Yuri's Pilot Card Inside.png Yuri's Pilot Card Template.png
Yuri's Pilot Card can be made using the template printed and glued on a thicker cardboard, then cut along the contour; the middle lines are for folding. The cover is then glued centered on the cardboard and the extra material is cut, glued and fold to the inside of the card:
(Note that these images are from the Loki thread about the making of the Official Handbook replica)
The Inside print is then glued again centered to the inside of the card. The finished card measures 210 x 74 mm when opened.
The Key Blueprint stitched together with minimal cleaning. Some of the writing and details are crispier, but some areas are blurry or lo-res. I don't know if the file is that way or in the scanning process the image had suffered some changes (maybe UnusualWizardry can confirm this on most files from the Secret Russian Content):
This blueprint has only 150 DPI, but a better version can be downloaded from my Google Drive along with the other files (the envelope is also in better resolution, not necessarily better quality) ==> Secret Russian Content - Google Drive. The size of the blueprint is around 550 x 392 mm.
And the pages of Hopper and the Demogorgon (higher DPI in the shared folder):
Hopper's Detention Report Front.png Hopper's Detention Report Back.png Demogorgon Necropsy PG1.png Demogorgon Necropsy PG2.png Demogorgon Necropsy PG3.png Demogorgon Necropsy PG4.png
These should be printed on a standard A4 (297 x 210 mm) on both sides.
Again, huge thanks to ribeiroorafael and his friend for the scans, which is the foundation of these files.
ribeiroorafael shared this poster (I think, scanned by someone else) in 4 separate parts and asked me to stitch them together:
I also cleaned up the folding lines and slightly increased the contrast of the image.
The above image have only 150 DPI, so for a better resolution (600 DPI), download the poster from here ==> Demogorgon Poster.png.
By accident, I have found the original Pocket Signal Disk seen in season 2, more exactly a for sale link on WorthPoint (citing eBay as the source of the actual sale - Oct 17, 2016 ==> https://www.worthpoint.com/worthopedia/1914-international-morse-code-1835124222); most likely it was bought by the production team:
And here are the photos from the site in pretty good resolution:
View attachment 1826525 View attachment 1826524
Wow great find!
In this post I will focus on Nancy's room. Photos of Nancy & Barb from the wall shrine:
Image369.png Image362_2.png Image369_2.png Image373.png Image362_0.png Image366_1.png
The 1st 2 photos can be found at low to medium resolutions in B/W, but none of them show the full photo or have some glare on them:
cab8a9ce9ef61d5593a4a91e31f313f0_3.jpg 0891925b675e35c0614ff12bc460e30f_2.jpg a0f84825458729d0e49dd4c37e7af36d_3.jpg Image362_4.png
These sources were used to create the full photos, slightly cleaned up, then run it through Topaz Photo AI; the base colorizing was made with HitPaw Photo Enhance:
cab8a9ce9ef61d5593a4a91e31f313f0_3-topaz-faceai-denoise-enhance-3x_3_072731.png a0f84825458729d0e49dd4c37e7af36d_3-topaz-denoise-faceai-enhance-6x_080124.png
While not perfect, it is a good starting point. I used my trusty old program (Jasc Pain Shop Pro 7) to make all the necessary color adjustments:
The 3rd photo was recreated using the clone brush tool (from my old program), but not before it was enhanced in Topaz Photo AI:
The Halloween photo have 100 x 80 mm, while the sunglasses photos have 95 x 80 mm.
The Nancy and Barb photo strip was recreated using 3 photos found online (most likely the same used by UnusualWizardry in one of his awesome posts), while the 4th one was made from a screencap with the magic of Topaz Photo AI. While the 1st photo is not correct (the original can be seen in very low res in the 1st photo strip screencap), just like UnusualWizardry, I used the same image not seen on screen:
The photo strip is around 171 x 40 mm.
And some posters on the wall:
No writing on the Tom Cruise poster; there might be another variant, maybe from a magazine, or it was added by the production team.
And the cat on the door:
Image367.png Image389_2.png cat-v-diana-ong-b-1940-chinese-american-ink-watercolor-private-collection-A0J5N8.jpg
Because only Alamy have this image, which is copyrighted, I won't post the cleaned up image.
RafalFett Wow! I’m very impressed.
I’ll be honest - I am not a fan of AI. I find it has mixed results and lacks the character of anything close to the originals. People look plasticky and text? Forget about it. This is why I typically don’t use it an opt for hand drawing or finding as good of sources as I can.
All that being said, these Nancy and Barb photos specifically came out fantastic! Really nice work! I’m definitely going to print these and add them to my collection.
Thanks a lot for the kind words!
I'm aware of the limitations of the AI programs, although Topaz Photo AI has a text enhancement option, I do prefer to do it by hand or search for the correct font(s); but when I have to enhance a photo by upscaling it, with the right settings, it does a great job (especially not used the word perfect). The secret of a good enhancement is to use photos that have minimum to no manipulation from photo editing software (no blur or sharpening).
I'm aware of the limitations of the AI programs, although Topaz photo AI has a text enhancement option, I do prefer to do it by hand or search for the correct font(s); but when I have to enhance a photo by upscaling it, with the right settings, it does a great job (especially not used the word perfect). The secret of a good enhancement is to use photos that have minimum to none manipulation from photo editing software (no blur or sharpening).
Very nice. I still have a license for it from when I tried it a long while ago. I’ve seen some other things from it that others have done across my network and it just didn’t look that great to me.
Maybe I should give it another try for some other things I’m working on!
New shares soon btw.
Good evening everyone, thanks for the shares RafalFett.
Some Identifications and replicas below.
Tiger's Wall s01e07 37m
Hawkins High School Drug Free Mural s04e01 35m AND s04e02 12m sized in 12x12''. FOUND HERE
Starcourt Mall Book Poster Breaking w/ Moscow [I dont saw this on series] sized in 11x14''. FOUND HERE
Bob Newby Hero of the Year Award OOAK [I dont saw this on series] sized in 8x10''. FOUND HERE. I do three versions of that, changing only images, one of them is the original one and others came from here
Laboratory Sign s01e03 35m,
sized in 3x3''. FOUND HERE.
Sam Goody StarCourt Mall Ad s03e02 25m
sized in A4 landscape mode ((11.7x8.3''))
Murray Mural Articles Newspaper s02e05 40m, sized in A1 ((84.09x59.41cm)). FOUND HERE
Murray Mural Article from Newspaper s02e05 40m, sized in A4 landscape, taken from here [[thank you once again UnusualWizardry]]
The next one I ask for a friend guesstimate after unfortune, since english is not my mother tongue.
Hawkins Book Store [[probably included in Murray's Wall s02e05 40m]], sized in 15x21cm. FOUND HERE
Joyce's Kohner Flyer s01e05 25m sized in 21x29.7cm
Now, some identifications, that one is from s04e07 52m Holly's (??) bedroom. Image from album cover can be found here as well
1717531930846.pngAlbum Cover.jpegthe-veteran-in-a-new-field-winslow-homer.jpgdownload (3).png99999.png
