Remote Triggered Sound Effect for Props?
On a side note of things..
If you are ever looking for JUST an "LED" control type of effect, that you want to interact/change things form your PHONE..
Using WLED is 10000% easy to use/install as well (requires NO code)
Summary:
Buy an ESP32 board.
Plug it into PC via USB cable
Open Browser/end point location (url)
Hit 'install'.
At that point (you can you select to connect to your local/home wifi,, where the WLED installed app on your phone will find it, and show display the interface).. if no WIFI, you can directly access the board via phone, and open your browser to see the interface)
not just colors, but animations/patterns..etc.
Are you still looking for something. For my Star Wars rebel costume blaster I have used cheap sound effect modules that you can download MP3/WAV files onto. I have 3 each with a separate sound file (and speaker as I dont know if they can be linked to 1 speaker) all mounted together with a battery pack which I have in my pocket. 1 module is triggered from a switch on side the pack to play an alarm sound. Then I have used a remote control relay switch to trigger the other 2 effects. I have hacked the transmitter fob to use an external switch which I mounted on the blaster and hid the transmitter circuit board inside the blaster. The receiver relay then triggers the other 2 sound cards. 1 plays a single blast sound when you press the switch and the other plays if you hold the switch down and plays a continuous fire. Attached links to Amazon parts.
Or photos here...
