Pyro X-Wing kit WIP
If you have a friend in Orlando, they can pick up some for you at Skycraft for 25 cents apiece.
Thankyou balibalopro!
Jason,Jay,
Thank you!
I found gold plugs or contacts or something in the RED 5 picture.
I think they are related to the contacts or the contacts.
I will try to find them.If anyone know what they are,please let me know!
And I also want the tube in brown that can be seen inside of the fuselage.
Thanks!
These might help ID them better - male and female ends:
Tubing:
Amazon.com: surgical tubing
You're correct that those are the female power connectors, some of which were mounted flush on each side of the fuselage and some of which came out of the rear plate through the Sherman hull part.
I believe the tube is just latex surgical tube.
Thank you Jason!!Those pictures are really helpful!
Kevin,
Thank you!The link doesn't work for me.
Its great to see this build coming together as well as it is. Some beautifully accurate additions to the kit, keep it going!!!
Thank you CutThumb!
I really love RED 2 X-Wing.To build my model better,I want to see the real RED 2 model in person someday.
Kevin,
Thanks for fixing the link!I think the size is perfect,but should the color be more like rubber band?
You are right Simon.
By the way,its so much of tube.It costs about 90 dollers including the shipping.:cry
You could try the rubber tubing you use on a dive spear / Gidgee. same stuff. check dive stores/ fishing supplies.
Thank you Robiwon!
I'm happy that there are some options.Maybe I can find at a local store.
As for electric contacts,I'm using "contact pin" as a keyword.
There are many many of contact pins.:cry
RKW,
Thank you!I hope I will be able to find it.
Frank,
Thnak you for watching this thread.The kit is really awesome.I have no idea how you pulled the parts out of the molds.
By the way,I'm working on the cockpit.I suspect if this TIGER part is on the back of the cockpit.
