Prop Replica STL files Section Free Personal Use
I am also getting the 404 when I click the "Download All Files" box at the top. I did not try that route when I uploaded the files. When I download from Thingiverse, I've gotten into the habit of going to the "Thing Files" tab, below the images, 2nd to the right after "Thing Details." After uploading, I checked that I could download the .zip, the Top.stl, and the Bottom.stl (in case separate files were easier for some to work with). I apologize for the oversight.
The "Download All Files" issue may be resolved at some point in the future. In the meantime, Jintosh and mrwax, or anyone who's previously had a 404 error, will you please try the "Thing Files" workaround and see if that works?
Yep, that worked.
Maybe the reason is that "all files" is TOO LARGE. o_O
The same reason you can't host here on the RPF.
7th Doctor's Tardis Key
I saw this elsewhere and made a quick replica.
For Personal Use ONLY.
  • 7th Doctor Tardis Key.zip
This is a great thread. Thank you to all the contributors.
Cheers,
Kevin
Yes, people have added some nice gems into the thread over time. A lot of times, I'll see someone else's build elsewhere and make a model to add here. Mine (such as the 7th key) isn't going to be spot on on the dimensions like the guy that cast from the original prop, but still, not bad for free.
----edited-----
B Wo showed that downloading the individual files instead of "all files" works.
And yes, this is why external links are less desirable. The control of the file is beyond TheRPF's control. For large files, there's just little choice.
There has been a glitch on thingiverse lately that when you click the download all it gives that error. they fixed it in the last few days.
"CREED" Saints medal from Constantine.
One of the charms worn by Constantine.
Print this at 15/16 inch width. 23.8mm.
This is VERY small. Extreme resolution is necessary to print.
Free for Personal use.
  • Final Medal.zip
REVISED : 1/11/2021
The TearDrop charm from Constantine.
One of the medals he wears.
For Personal use only.
  • Constantine TEARDROP 10.zip
Does anyone have this EZ Sleep .stl by any chance or know where I can purchase it? It seems it use to be on cults3d and it disappeared. :/
It’s available again!
Does anyone has a good Beskar ingot file with the right pattern? I can't seem to find one! Even one stl for purchase haha!
The Mandalorian.
Beskar Ingot
-----edit-----
I finally came back and finished this.
UPDATED 10/6/2021
Free for personal use.
  • Beskar Ingot Final 4.zip
Here is a name plaque for the Rocketeer helmet. I finished this with Rub and Buff antique gold but I may redo it with something a little more "brassy". It has an Art Deco motif with the Aeronaut font. I scaled this up by 25% to make it about 7 3/4" long.
  • Rocketeer Plaque.zip
Wheel of Pain from Conan the Barbarian (Schwarzenegger)
Can be used as a necklace, like in the movie.
For personal use only.
  • Wheel_of_Pain_FINAL.zip
The bunny statue from ROMANCING THE STONE.
It is hollow and properly sized so that RelicMaker's stone should fit through the hole in the bottom.
  • Romance Stone Bunny.zip
