Prop Replica STL files Section Free Personal Use
The metal version of Conan's wheel of pain from Conan the Destroyer.
Free for personal use.
  • metal pain wheel 7.zip
This is my bracket file for attaching solar panels directly to a standard Tpost for quick rural installation or camping. The file is saved as AI, adobe illustrator and is final size 4 inch by 2.5 inch. My own design so not protected, please use. I suggest 3/16 sheet steel to get the appropriate hanging angle on the tpost.
  • solartpostbracket4x2_5inch.zip
And the above as an STL.
  • bracket for solar panel.zip
NERF PULSE RIFLE STOCK
Here is a replacement stock for the Nerf Pulse Rifle. FDM in normal settings. The support material removes really easily. Just clean the pin holes (I used a drill bit in my fingers the same size) to make a smooth fit. The shroud sides clamp tight. Give them a squeeze and it snaps together around the stock. Cheers!
  • Nerf Pulse Rifle Stock.stl
Not a bad idea, though there seems to already be a model of the key up on shapeways. No idea why it isn't available in metal.
_A
If you upload it (by creating an account if necessary) then you pay COST, not cost+markup. Print it yourself. :)
My apologies if this derails the convo and I am surely willing to be directed to the right thread but after many years using bloated software that is not intuitive, does anyone have tips and favorites for design software? I was leaning toward 360 as my next study but am seeing really low ratings. I happen to really like most Autodesk products but dang, a 2.9 of five? Thoughts or name of thread if there is one?
