Original ESB/ROTJ stunt Vader saber going up for auction...
I don’t think these dents were from being hit by a blade, I think these dents were from being dropped on the ground between takes and thrown in storage between movies
To me, the blades are weaker than aluminum.. path of least resistance, the blades would break first before the aluminum
But my way of thinking, I have no proof this is the truth.
Agreed.
I think this is pretty safe to say is true; the fencing "blades" were composite resin and fiberglass things. Basically the same as Vader's mask and chest armor. They're anchored to steel and solid cylinders of aluminium. I believe the MPP shrouds were also alu and/or steel, too. It'd going to take something pretty substantial to get it to bow the way it does and where it's bowed at. Maybe it was a repair when the shroud got dented by something else?
The clamp screw appears to be a 10-32, pan head, slotted screw
Not quite. The blades themselves were fiberglass and an old carcinogen filler, with aluminum and steel inside the bottom few inches.
I’m with you guys, unless the metal reinforced base of the blade struck the shroud, the rest of the blade wouldn’t do anything. Could be that it was bashed against a guard rail lol
Micro Precision Products were an UK company. Would this be an M5 or something instead? I’ve never owned an MPP and am not sure the thread count
The replicas (at least Roman’s) appear to use a 10-32 thread.
I believe the metric equivalent would be the M-6.
My old ex-MoD Land Rover was made in 1974 and about half the bolts on that thing were metric, and most of the rest standard. A few oddballs were even British bolt sizes, of which there were several standards! :lol:
Here is my theory…those bolts are designed to hold the “core” in-place in the flash but the bolt at the bottom—that may go through the “Tang” actually “anchors” the “tang” in-place.
I'm going to slightly disagree here again. I believe what you are seeing is actually yet another separate collar part/piece within the internal assembly that is positioned on the bottom side of the lower large aluminum plug housing the large body screws. The intent of this is to allows for a safety ''stop" for the steel rod in case the rod tries to slip on the main long screw in the lower aluminum plug. It seems they wanted the option to make the length of the rod exposed out the top to be adjustable if they so wanted, while assuring the rod with a blade on it wouldn't suddenly javelin itself across the set at someone on a heavy swing, especially if the theory that the blades were surplus fiberglass antenna of some kind for ESB is true.
A simplistic but smart solution to a sturdy stunt prop
. I think i'm most definitely building this puppy out of my spare narrow port mpp tube :love:
Edit: I was mistaken and overthinking the design, not thinking about the clamp, as PoopaPapaPalps kindly pointed out
Yeah I truly think you're overthinking this. That's literally the slotted screw running through the clamp bars, which are also visible on the x-ray.
We can kind-of see 3 of the 4 allen bolts for the lower core, one facing the camera and the two on the sides.
LOL at Savage talking about the Pelican case like it's some great thing. That's one of the cheapest cases Pelican makes.
The dent looks like a buckle from being dropped to me.
