New 10th Doctor Sonic Screwdriver Universal Remote
there isn't a spring, the clear stem engages directly with the micro-switch. This looks like a whit rectangle in a black frame soldered onto the circuit-board. there is supposed to be a small bit of metal on top which when pressed by the stem will bend and push the micro switch, but will spring back to its bent state when released. this may have come off. But the main problem seems to be with the metal circle inside the micro switch. The way the switch works is this: there are to contacts on the circuit board, not quite touching. when connected, they complete the circuit. sitting above the contacts (housed in the black frame and kept in place by the white film) is a small, slightly convex circle of metal. When the stem of the transparent button presses it down, it "clicks" and becomes concave, and connects the two contacts. When the button is released, it should spring back to concave, but sometimes it gets stuck. then we end up with either an extremely sensitive or permanently engaged switch.
Mine doesn't appear to have any extra blue plastic, so that's weird?
Thanks for for the info on the stem! I'm guessing my little metal bit got bent when I dropped it on the concrete locker room floor - it was one of those moments that in retrospect happened in slow motion with the switch side hitting the floor with a sickening crack....I'll probably have to send mine in for a proper repair, tho it seems to be better than it was at first. I did email TWC but I think I may have used the wrong email address, so will try the one posted above! I immediately ordered another one overnight as I couldn't gear the thought of being without it! I seriously think I have some obsession issues with this gadget, it's so cool! Anyone else feel such attachment to their Sonic? (Ie pleading for Yes answers so I don't feel like a basket case, lol!).
As for the additional inner blue strip, I took a pic so everyone could better understand what I'm describing since it would be impossible to see unless you take it apart:
and here's both strip inserts actually removed. The one with the little notched end is the hidden side. I just can't figure out the purpose of it, even the notch doesn't seem to serve any purpose, so I don't understand why they went to te expense of sculpting, molding and manufacturing and assembling this extra piece! I also noted the strip that is visible has a white coating on the inner side, presumably to make the translucent blue pop as it does. The alt side does not have this, so I thought maybe they were swappable so the led indicator lights might show thru with the alt insert in place to give a sort of visual indicator of power or readings levels for the Doctor to read - but the notched end sort of spoils this theory as if you swap the sides the notch leaves an open bit towards the bottom end. Absolutely bewildering!
Funny how such a small thing can obsess one. Hopefully someone from TWC will reveal its purpose! :)
Actually we could already program the Sonics using the same method as entering the Unlock Code - i.e. just press the main slider button in succession, pause briefly, then enter the second digit, etc. just as universal remotes come with a guide of codes to program them so the standard controls work without programming each button.
Now, this would involve a bit of compromise in that there would, necessarily, be a standard gesture for each control so the automatic mapping would know what to map to. *But* if, for example, you want "Push" to be select/Enter instead of the universal standard of Power On, you'd still gave the option of press press hold to re-program as many gestures as you wanted whilst leaving the others the agreed upon standards.
I'd also be more than willing to pay more for a higher memory model, say 6 or even 8 or more banks of commands instead of 3. Heck, I bet there are many customers out there who would happily pay for a "Deluxe Sonic" model with double or triple the memory bank capacity *as well as* additional features (true sonic option for sonic remote devices, Geiger counter, radar detector - I'm joking on these last two (mostly). :)
The thing is, now that I have held one of these beauties in my hand, and used it - I am shameless to say I am obsessed! I literally carry it with me everywhere! Please tell me I'm not the only person who does this? :) Before I bought one, I thought it sounded cool, but using it has made me realize how much I'd splurge for a feature rich deluxe version.
Wand Company - you guys have become the pied pipers of the gadget lover in me! :)
More banks would definitely increase the capacity for commands but I know I'd have a hard time keeping track of which banks were for what. Hell, I couldn't even tell you what the current three banks on mine control or which gestures do what, lol. I know there are some for my TV on there and some for the air conditioner at my regular bar that I programmed for ****s and giggles haha.
But having an app on your phone connected via bluetooth would mean that everything could be stored and labelled. It could pick up on the commands you program with the remote directly, or access a database for the commands and store them all in sets of 13 named for the device(s) they control.
The only problem with this is that the sonic loses its independence - plus the inconvienience of having to pull my iPhone out everytime I want to use my sonic.
Yeah, it's give and take either way. But who doesn't carry their smart phone with them everywhere and have it out multiple times a day? It would be a small memory usage app that could run in the background at all times, and if it had presets, you could access them quickly for whatever device you'll be controlling. I just think the UI on the app would be far easier to use for managing numerous banks rather than having to remember what the controls are for every single bank.
I definitely want the Sonic to stay independent and not *require* an external device like a Smartphone- but *optional* communication as a means for quickly configuring the Sonic by downloading Universal Remote Profiles would be a fantastic option! But I strongly feel the Sonic should always remain independent and offer a method for configuring on the device itself.
Since we're dream designing, how about:
1- More on board memory for more memory banks/registers ("..Memory Bank G.", to store controlsmore devices, that's a given and a logical step for a "Deluxe" model that shouldn't increase cost/complexity much - but then again only TWC knows what this cost would be. Is such a thing even possible if any WC reps can venture a maybe/no/yes! :)
2- I love the idea of BT comms, but if that would add too much cost or not be feasible. then heres a cheap alternative: the USB charging port becomes a full fledged USB data accessory connector port. The Sonic would show up on a Mac/PC as a drive or other device (the ability to store files like a thumb drive adds to the geek chic utility!).
Also, if a significant amount of added memory becomes available, would being able to custom name registers be too much? A microphone to record voice seems a bit much, but perhaps via the PC interface app? Some predefined voice labels in the sexy Brit voice ("FX Mode, Practice Mode, Memory Bank Stereo, Memory Bank: DVD, Memory Bank C, Memory Bank Stereo, etc..."). Oh, how about being able to make Practice Mode accessible only via special button press? Or could you even use the gyro to input the bank desired by gestures? I.e. "What device do you wish to control?" (Trace a circle in the air for DVD player, draw a rectangle for Stereo, etc. I know, that's a little wild, but it totally bet it's possible and would make an awesomely unique method of entering data! Or even the WC equivalent of the Android visual unlock code!
3- Okay, so either via BT or via USB port & cable: While connected to a computer, you could use a simple comm program to upload standard Universal Remote codes to control devices, just like Univ remotes you buy at the store without all the tedious individual learning of functions. This also becomes VERY useful if you've lost or damaged the original device remote - and would potentially increase sales significantly as people could factor in the savings - and time - of buying/ordering a new remote for their particular device and order the Wand Co gadget instead! :)
4- Now, a big question would be: how can I automatically control a device with gestures? To answer this- there would need to be a *default* gesture <-> control map for the most common controls (and even standard Univ remotes don't always cover unusual feature functions, and some simple devices may not even use all 13). Thus, when you downloaded code 5984 for Sony DVDs, the built in 12 or 13 gestures would always map to the same thing (volume down/up always anti/clockwise, select always Push, power on always pull, etc).
5- Now, if you so desired, you could STILL enter programming mode and re-program or learn the original remotes individual functions to map to whatever you wanted and keep whatever default mappings untouched as desired. This allows easy use, but full customization as well (say if you like most of the default settings but really want Push to be power on and Tap in the Top to be select, then it is!).
6- want to enter a Device Code to automatically program your Sonic like standard Univ remotes work? Just use the main button to key in the individual code digits - exactly the same way you enter the Lock/Unlock code now! (This capability sans computer necessarily implies an inboard stored catalog of Universal remote codes...but since cheapy Wal Mart Universals can do this, I'm sure the Deluxe Editions of TWC 11th, 10th and 4th Doctor Sonic Screwdriver Universal Remotes can too!).
I do think of the above features additional memory banks and automatic device setup via coded entry should be fairly easy to implement provided we are willing to pay the price - which would hopefully not be too drastic an increase as it essentially is more storage.
As I said, I LOVE the idea of having BT communication capability in the Sonic, and the above suggestions don't even begin to cover the enhanced capabilities such a device would have,if fully exploited. IR *and* BT Control options? WOW, you could remote control your PC or iPad! You could control presentations for work! You could do <insert function here followed by maniacal mad scientist laughter>. That might be too pricey but dang, I'd go for it in a heartbeat if less than $300. And probably more after a few seconds consideration. :)
Throw in all the above: BT control, USB Data comm and increased storage, on board codes for various devices, as well as a Geiger Counter and blue laser pointer option and I'd pay close to half a Grand easy! ;-)
Thinking about it, I'm not sure a new DT sonic makes sense. Imagine the sonic is an iPhone and the TARDIS is Apple. Every sonic iteration should be better than the last, just like how iPhone 6 will be better than iPhone 5.
And that's been the case in the episodes: the first sonic could only do basic functions, but the latest sonic (Smith's) can scan and do much more.
So, the Wand Company should do a Capaldi sonic with loads of better tech (like more storage, etc.)
I think a better DT sonic would feel out of place, but an improved Capaldi sonic wouldn't.
http://i1164.photobucket.com/albums/q571/GeminiPete/2b624a645bd9ce844bedd3733bb9fb29.jpg
http://i1164.photobucket.com/albums/q571/GeminiPete/8c75e211facb7c190df42519319a5f7f.jpg
I feel the same attachment, You Are Not Alone! (Sorry, couldn't resist)
Here's mine without the extra strip, and also a shot of a series 2 conversion I'm working on. I don't think I'll make it into an Aztek, but I liked the idea of having the black/red wires variant.
I've done the exact same thing, but unfortunately the clips of my handles are broken, but that's not the problem, the grooves were filed down a bit my mistake and it dosent look any good anymore, I'll post pics to show you
Here are the photos of my handle grooves and the replacement I added for the clips
New updated version of the remote. It has less anodizing, so the metal shines through, other than that, it is mostly the same.
The slider is now secured with a spring rather than a little bump on the handle. This is more reliable and won't wear down as much as the initial release did.
This was an update that was made after the initial release.
Pics are below.
1st release is the matte finish one, shiny and in closest to the charger is the improved version.
Pics are below.
[url]http://i1289.photobucket.com/albums/b513/Bluebox303/IMG_3443_zps21694644.jpg[/URL]
[url]http://i1289.photobucket.com/albums/b513/Bluebox303/IMG_3445_zps248c4267.jpg[/URL]
[url]http://i1289.photobucket.com/albums/b513/Bluebox303/IMG_3444_zps98f97b71.jpg[/URL]
From the pics, I can't see a difference between the two sonics in terms of 'shininess' - maybe that's just how the light fell in the photo.
The spring sounds like a good idea. I'm interested in the purchase of the second sonic - did you want more memory, were just curious, or are you modding one of them???
The Wand company is the one who produced it. IN person, the difference in the metal appearance is very clear. It is just hard to see in the picture, the last photo shows it the best.
I think you misunderstood me. I am interested in why YOU wanted a second sonic (I don't think I need two).
Here are some pics of my Wand Remote Turned into a 9th Doctor's Sonic
The modifications to the wand sonic that I made were designed to turn the existing remote into a prop replica of Chris Eccleston's Sonic Screwdriver from Series 1 (which was also used by David Tennant in Series 2).
You can see a good pic of the original prop here
