My HP Quidditch Trunk [Completed]
I was back at ENTS this week, still no 3D parts printed, hopefully soon.
In the meantime, I cut a ring out of this wooden plaque with a scroll saw and sanded it to shape. This will be a ring around the quaffle to make it look nice and clean rather than the rough metal lip.
I then cut the crests to rough size and sanded them to the proper profile.
I sketched up a pattern for the inside flowers where the crests will go, cut it up to 8.5"x11" sections and printed it off and transcribed it to my hardboard.
I then painted up the crests to their matching color schemes
Then painted up the gold flower pattern on the hardboard, Here is a mockup of the placements of the crests.
What a journey! This is such a cool project, I can't wait to see the final result. Are the 3D parts being printed in resin? Do you plan to weather/age the trunk/paint at all? I can't wait to see the final result, watching for sure.
I had a productive weekend, I finished up some paint work on the ring, and around the rim of the box and lid, and clearcoated the exterior of the box.
Then I glued the crests onto the main board, the board to the inside of the lid and the ring to the top of the metal quaffle bowl.
Then I reassembled everything, now just to wait for the 3D parts to be printed, here's where we are, so darn close.
Thank you very much. So there is a mixture for the printing. I'm have the corner protector printed in Resin so I can mold and cast the remaining copies and have a nice clean shape for the mold. I am also having the doors for the snitch compartment printed in resin as they are detailed and I don't want to have to do too much finishing for that feature.
The rest is all FDM printed. This is also highly because of the size of the prints.
I am planning to weather the trunk before I'm all through with the build, hoping to be able to progress further soon, I have my deadline of Sept 15th now to have it ready for the competition I'm putting it into.
Fantastic work! What program did you use to design your bludger plates and collar rings? Did you print them out of PLA? Any issues with them being too brittle?
So, I was able to pick up a couple of the prints the other day and did some cleanup:
Printed in PLA, no real concern about brittleness, all features are thick enough.
Here's a closer look at the locking mechanism:
And a look at the bludgers:
And here's how it all fits in the trunk:
Here is a pic of my Snitch in the snitch compartment.
Time to do a bunch of finishing, painting, and such, down to only needing 4 more parts. Plus some hinge pins that I'm have difficulty sourcing.
Update on the finishing of the 3D prints I have, I started by cleaning up the prints, and doing some "damage " to the bludgers.
Then I painted all the components of the rings and the bludgers gloss black.
Next step was to apply Pewter Rub n buff to the ring components and the bludgers surfaces:
It was time to glue these up, so I picked up some Akfix 705 CA glue.
This stuff was a life saver and a pain in the butt. It only takes it 7 seconds to set or so. But that leaves next to no time to adjust placement.
When gluing the bludger ring latch, I had to include a rubber grommet on one side to stiffen up the latch and allow it to function properly.
When this was done I was riding high:
Next up, I cut the rim off the smaller bowls with my Dremel and glued them to the bludger rings with No More nails:
Next up was the lock front plate. I lined it up and taped it for painting:
Then I glued this in place also with No More Nails:
Will just need a bit of touch up for the paint to line up, and then clearcoating.
Next, was applying a rust paint job to the bludger which involved stippling painting with 3 different colors, Burnt Umber, Honey Brown, and Terracotta. I followed a technique I saw on You Tube and was very pleased with the results:
Credit to CreatingThroughChaos for their great tutorial:
And here we are.
Now to talk about the corner pieces.
I got the piece printed in resin with the intention to mold the piece to save time and have nice copies.
Everything looked great and good during setup and pouring, but when I went to demold the original, I found the the silicone touching the surface of the piece was still gooey. I pulled my original out of the mold and let the mold cure, for 5 more days. Then I casted a piece in it, to find it all melted looking.
I decided to re-mold the piece after I coated it in primer + paint so I molded it again:
This mold came out much better, with a very small amount of gooey, so I casted in it, and aside from a bit of bumps that can easily be sanded off, it looked good.
So, I casted the 12 pieces that I needed:
All that's left for that is to sand, and paint black and they are ready to be glued to the trunk.
PSA: I talked to a number of other makers, and they all said the same thing, Resin prints continue to Off-gas after curing to the touch for up to 30 days after printing. Because of this, it will cause Platinum-cured Silicone to not fully cure. So you have to coat the surface in a primer or other coating to allow the mold to fully form. My second mold mostly cured because it was coated in primer, but I guess the paint wasn't completely cured cause some flaked off and reacted to the silicone.
Finally, I remodelled my Bludger Top Holder after some discussions with my friend doing the printing and came up with a 3 piece assembly that should be much easier to print and to assemble, and less fragile.
Winded down, I should have the compartment doors and the bludger top piece prints this week. Once that's ready to go, it's on to the final stage, weathering.... groan.
Since last posting I have been able to finish up quite a lot of the build.
Firstly, I was able to get the doors for the snitch compartment resin printed and they look great:
Next step was to paint the corner pieces and the doors. The doors are painted black on the front for the rub n buff and green on the back to match the interior color.
Then I applied rub n buff to the front of the doors:
I realized that I would need a custom hinge pin, so I modelled that up and got it off to my friend to Resin print for me.
In the meantime, I picked up the bludger top holder pieces, here's how it looked cleaned up and assembled:
I also cut my chains to length and tested them out:
I picked up my hinge pins, and painted the doors with enamel paints:
After painting the bludger top pieces and the hinge pins black, I applied pewter and gold rub n buff respectively.
Then I glued the compartment and the bludger rings/bowls in place with no more nails and glued the corner pieces on with Akfix 705.
Here it is, looking mostly brand new.
Then I started the weathering:
I used a combination of Burnt Umber, Tan and Black acrylic paints dry brushing, and streaking across the inside and the outside of the box, and I arrived at this as my weathered look.
The last bit I still need to do is the mascot symbols on the front, lid, and back of the trunk and it's all complete. Whew! that was one hell of a few months.
What an awesome update, everytime I check in, there is just more and more being added, it looks so great! This is a totally amazing build, have you considered what you're going to do with it once its complete or how you intend to display it?
What an awesome update, everytime I check in, there is just more and more being added, it looks so great! This is a totally build, have you considered what you're going to do with it once its complete or how you intend to display it?
Thank you, super duper close to the finish, I'm just waiting on the custom vinyl labels I ordered for it.
I have not figured out where I intend to put it when it's complete, but I assume it's going to sit in my disney themed guest bedroom for now as I don't have enough space for it in my office.
I had the replica all ready and out on display for the Edmonton Expo Prop Replica Competition.
Unfortunately, I did not win the award for Best Experienced maker this year. That went to fellow RPFer Kokanee which I felt put forward an amazing prop and was a pleasure to chat with at the con.
I did end up winning the Fan Choice Award, which was not expected but was a great honor:
To cap the day off, I was able to get a photo done that I really wanted to since finishing this prop of my wife and I in our school gear carrying the trunk.
Hope you all enjoyed the process, it was a fun but challenging project.
