Mandalorian Reference Thread
In honor of finishing my 60th Bo helmet, I figured I’d share some quick shots.
I don’t think I could ever get tired of these.
These particular helmets are cast by GEC Props and sculpted by Marko Makej. All credit to those gents. What an absolute joy to paint.
I am more impressed with your paint application. That is phenomenal. I want to know how you get that mottled effect over everything. That just makes the whole look.
Agreed. Are using the salt masking method, or do you spray water on it first then paint it before the water evaporates?
Happy to share. It’s really simple, I just airbrush on the weathering color.. it’s a very thinned out grey. Then I splatter 91% alcohol into it.
If your alcohol is too “hot” sometimes it can turn the paint white, so water it down a bit or clear the helmet at the end. But better to avoid it.
If anything is too heavy I dab it with a sea sponge.
Nice! I will be trying that.
That effect absolutely makes the whole look.
Thanks for sharing. Since you use alcohol I'm guessing your weathering colors are acrylic.
My Tank Trooper build. Went with a red lens based on the Hot Toys figure and a couple shots where it looks like it could be red. Either way, I thought it looked cool. I also went with a more subtle weathering job.
Used these files. It was the only design I could find that featured the under-skirt greeblies.
I've looked high and low and can't find the answer, which usually means it's something obvious and I'm dumb, but how does the rifle secure to Mando's back?
Episode 1 suggests that there is a quick release clip on his shoulder but where does it attach to on the stock?
And how is it secured at the other end to keep the whole thing from swinging around?
There are no stupid questions, only questions YOU don’t have the answer to yet!
First image I’ve circled where the sling attaches to the bandolier. Second image shows a loop that is attached to his belt that holds it at an angle. There appears to be a hole in the cape that grants access to that loop. Third image is the bit the sling attached to.
HasbroPulse just announced the Nerf Boba Fett EE-3 Blaster. I haven't looked it over in great detail, but I am assuming it's going to be as inaccurate as the Mandalorian Amban phase-pulse blaster.
I am comparing to this picture and except for the obvious color differences, it's looking pretty close. Hasbro has it listed at 30" in length.
I ended up cancelling my Amban rifle because it was so far off, but I may order this one.
Yeah, that size seems pretty close (still finishing my 3D printed version so can't really compare) but we'll see, I just pre-ordered it.
