Luke's Lightsaber Mando series finale.
Have to thank division 6 for the 4k screen caps
The one thing I really like about the Luke TV series hilt is that the tri-ring is not aligned with the control box (which makes it near impossible to wear). So much so, I don't even care about the accuracy of this version of hilt design has this, and this the other version of the hilt design has that , and then the other version of the hilt... I myself would be just happy with an idealized version of the hilt in which something like the pommel was spring loaded. The pommel would be locked in place, then you push down and twist to put the tri-ring in a new orientation. Then you release the pressure and let the spring loaded pommel return to position leaving the tri-ring locked at its new orientation.
On my Mando Luke model, I have it so that the pommel cubes can rotate and the pommel cap keeps the cubes in place where you want it when it's screwed into place. Sorry, spring loading is a bit beyond me ;)
Oooh nifty. And necessary it would seem, as it looks like between Mando S2 and BoBF the tri-ring has once again moved…
Just about the Order 66 Jedi, looking at the screencaps they all seem to use the same Lightsaber design, this gives me the feeling that they filmed the same guy twice, once with the robe and once without and split him into three Jedi, or they had three Identical Lightsaber hilt props which given that they're supposed to be Prequel era Jedi would be very fitting.
We get a really clear view of the emitter flanges here
I think the light is blowing out the corners, so they're not that pronounced, but this saber to me is noted by the tall emitter sections and normal plate
Y’all have powerful image editing power in your photo programs on your phone. Use them! Adjust contrast ratios, shadows, exposure, etc. the digital algorithm is a powerful tool when you’re examining digital photos (especially when eyes can fail)
