Now onto the business end of a lightsaber, the emitter.
The FX saber has a black plastic plug with a hole the blade passes through. The blade is then screwed to an internal plastic assembly that contains the electronics. This all slides into the end of the sabers metal tube body.
In the below pics you can see the stock FX saber. The black plastic plug is visible through the holes and by its overhanging lip.
(Photos courtesy of saberproject.de)
I'd disposed of all the electronics and the blade as my intention is to make a display hilt. The pairs of brass pins either side of the saber ere mounted to the discarded parts, so I needed to figure out a way to attach everything now they were gone.
I started with the existing plug. it was in 2 parts, so I glued them together first. Next I corrected the shape by rounding off the sharp edge of the hole where the blade had been. I also sanded smooth the plastic to take away the shiny cast look of the original plastic.
Then I corrected the shape of the overhanging lip. The two notches either side came straight out rather than at an angle as I'd observed on a real Graflex. Finally I polished the plastic with Tamiya polishing compound to give it a more refined finish.
In my stash of random junk I found part of an old glass shelf mounting bracket. It has a really nice solid brass rod which screwed into an aluminium base. I thought this would make a perfect centre piece to the emitter. A real Graflex has a similar brass plug where the flash bulb attaches.
The diameter of the brass part is a bit wider than the plug in the end of a real Graflex but was close enough for me. Plus, it added a lot of heft to the piece which was a nice bonus. I knew that part would come in handy some day!
To add a bit of detail, I drew up a circular pattern which I laser etched and cut into a clear acrylic disk. This had a hole in the centre that fitted around the threaded part of the brass rod. This still left enough thread exposed to screw into the aluminium base. The idea behind this disk was some kind of emitter that would focus energy into the blade of the saber. When you peer into the end of my replica it would be visible suggesting internal workings.
Here’s a shot of the parts after I’d polished the brass and cut the ‘emitter’ disk.
And here are the pieces together.
The next job was to come up with a way to mount these parts together that would fit into the outer metal sleeve of the saber.
I had some 40mm black PVC plumbing pipe lying around, so I decided to use this as the base to mount the existing and new parts onto. It’s wider than the saber so in order to get the correct OD on the pipe I put a piece of masking tape around the inside of the saber body, cut it where the two ends met and then wrapped it around the pipe. I figured if I cut a strip out of the pipe the same width as the gap in the tape, the pipe would then be the correct size to slide into the saber body.
To cut the strip out as straight as possible I used a square rested across the end of the pipe to mark a guideline on the outside of the pipe. I then used it as a guide to score and trim the pipe until I’d cut the strip out.
I made two parts this way. The shorter length has a wider strip cut out so it can be inserted into both the longer piece and the black plastic plug from the FX saber that I’d modified earlier.
Due to cutting quite a wide strip out of the smaller length tube it had a bit of a teardrop shape. I rolled it under pressure against the desk to try and round it out.
It now fitted perfectly into the end cap. This tube forms the inside of the emitter as well as the back wall of the black circles where the brass pins attach. This is visible through the metal outer sleeve of the saber body in the second image below whilst test fitting.
The next image shows the above assembly slotted onto the larger diameter tube.
To allow the brass emitter part I'd made earlier to fit into the sleeve, I bevelled the edge of the inner sleeve. The aluminium base plate of the brass rod had a bevel to it so this would help it seat in place. The aluminium piece will be epoxied into the tube later on. You can also see that I've sanded the outside of the PVC tube here as it had a bit of an uneven surface.
My next job was to fit the brass pins back in place. To make sure the 4 holes were consistently positioned I made a drill template. I drew a vector drawing for this and then laser cut it from mount board.
The lines at top and bottom were to help me line it up with the separation line of the two parts of the end plug. The two lines at the left were to allow me to carve a channel for the brass tabs connected to the top pin. These were not included in the stock Force FX saber so would need to be made from scratch.
In this next image you can see the channel I've carved out for the brass tab. I’ve also sprayed the sides of the assembly with Tamiya X-18 Satin Black. I found the PVC not great to work with, it’s almost fibrous when sanding and cutting. As a result the work I’d carried out left it with a grey colour so this gave it a much cleaner finish.
For the brass tabs I started with a scrap piece of photo etch fret from a 1/24 Harrier upgrade set. I tend to always keep unused PE parts and their frets as it’s often really useful.
The piece on the left is what I started with. On the right is a piece that’s been cut to the correct width (just scored multiple times with a scalpel), cleaned up with some sandpaper and then drilled to take the brass pin (seen in the middle).
Next I used a grinding disk on my rotary tool to round off both ends.
Here’s a shot with the pin inserted to test the fit and check the curve is even.
I then needed to bend the piece in 2 positions to create a step that would drop down into the circular indentation. To do this I lined the brass piece up using a suitably sized drill bit. This was passed through the hole in the brass and into the hole in the PVC tube to get the correct position.
You can see above that I’ve marked the point where the brass needs to step up. The piece was then folded using my PE bending tool.
Once the first bend was in place I could work out the position for the second.
And here is the finished piece installed. You can see in the image that the brass was treated with a blackening chemical to give it a bit patina. The brass pins will be glued in as part of the final assembly.
After this I epoxied the emitter rod into the PVC tubes and this part was completed. The images below show the emitter rod installed. It gives a really nice sense of depth to the end of the saber, although it is difficult to capture that in photos.
