I drew you a picture maybe this will help as writing it out is kinda confusing
.View attachment 556845
perfect, thank you! did you do the same for the battery compartment and side buttons?
In my comparisons so far, it seems the flare on the back isnt quite as long as it should be on the Hasbro one, but the overall size and shape is correct. The cheek areas need to have a few small holes added, and some of the extruded areas inside the cheek holes that are there, removed. Speaker and breathing holes need to be filled.
Or you could use this stuff here, its' amazing... http://notaglue.com/ and save yourself from the noxious fumes lol
Is this a viable solution for bonding the helmet together and patching some of the seals/gaps?
Overall the detail is a lot softer than the Anovos of course, because its molded abs plastic.
