Jackieisrockin's Iron Man Mk 42 Pepakura Files! Back added to first post!
I know this gets asked alot about rezeing but its confusing me to hell...
Could someone help me. I am 6 ft 3 inches with a waist of 42/44" and a chest of 50" and a belly of 52" lmfao!! yes i have a gut!! :)
Head circumference of 24 inch
how would i scale this..
I Usually pick a piece, like say the abs and then measure it in diameter with pep Designer... then change scale in the 2D scale section until its around my own diameter just a little bigger obviously , so its not a squeeze... and then do the same for all the pieces or just copy that one piece's final scale and then pasting it in each piece, keeping in mind they then all have to have the same default scale :thumbsup
Hope it helps...
Try as i might i cannot figure out if there is a MK 42 bicep and shoulder unfolded for paper anywhere on this thread, or elsewhere that will match up with the forearm provided by jackie. Does anybody have any insight on this?
Hello that such friends, I am new to the forum and I would like to share some pictures of the costume Iron Man Mark 42 I'm doing, credits are for helagaks and jackieisrockin I hope you like [Iron-Man]_mark 42.jpg iron man mark 42.jpg
Dremel thank you very much, really are the same files for foam, I just joined the parts with small strips of paper as seen in image pic.png
I know its a bit late cuz this suit has been done for a while now and I have been MIA...So Just for you Jackie.....Thanks for the great things you and the others have done. Not just for me with this suit but for the RPF Community. Keep Up The Great Work! :thumbsup....I'm gonna add some better photos suited up later.
For all those who have built the boot using cardstock/fiberglass, how did you get the inside of the boot? It's a little difficult to resin/fiberglass the inside of the boot.
Excellent work Blackdynamo2
Man this is impressive! I already built a mk7 suit and it was relatively simple, but with mk42 I'm struggling for the scale value because I don't know how to fit it right for me :( So, in front of such perfection, I'm hoping we are the same height so that I can set your scale value..how tall are you? And which files did you use? Thanks!! Any other help will be appreciated :D I'm 5,91 ft!!
Looks great!! good job dude!
