liloandsith
Active Member
that method won’t work on a single layer cloak that needs to blow dramatically in the wind and gather so it lays correctly.I tend to make my own weight (I know, more work) I usually take the same design/form that you'll find in men's collar in a regular shirt (to keep the points of the collar from curling). I simply took 3 collar's stays (glued together to make it thicker), made a plaster mold of it. After the mold was done, I poured lead into the stay and voilà! Works well and my ends are always pointy and don't curl
you could just use interfacing for any collar of any shape which is how they’re done in the industry. they make sew in (which i recommend) or iron on. they also have different weights of interfacing depending on how stiff you need something. i used the heavy duty interfacing for my Padme kimono sleeves. but using interfacing requires a lining that will sit in between.
