Fallout 4 laser pistol build
Thanks! I pulled out the decal kit I had, which said it was for inkjet. I bought it like five years ago. I noticed it has a sticker over the inkjet part saying "Disregard, this only works for laser printers." :facepalm So I'll have to get another set.
UP-77 1.jpgUP-77 2.jpgUP-77 3.jpgUP-77 4.jpgUP-77 5.jpgUP-77 5.jpgUP-77 6.jpgUP-77 7.jpg
- - - Updated - - -
DONE !!! However I will make improvements on the next ones along with mods to the case .
franco358 I bookmarked that decal kit. I always hated that water decals end up with a film around the text.
Are you distressing the text in the print, or doing that by scratching it off afterwards?
@franco358 I bookmarked that decal kit. I always hated that water decals end up with a film around the text.
You can get around that by trimming and then using a decal setting solution like Micro Sol. It will make the film disappear. You need to test a section of the decal sheet first though because it can eat some types.
No , I distress them after I apply them . If you distress them by hand afterwords they will all be different. Then weather over the Transfers and seal them with a clear coat . You'll need a laminator and a Laser printer to do the dry transfers .
- - - Updated - - -
Yes , and if you weather over the decals it will also hide the clear film too.
