Fabs homemade Indiana Jones Props
So finally time for another modification. I put birdshead grips on my Webly Mark VI Airsoft to get a close(r) enough Version of the WG used in LC and CS. I traced the grips on the the frame, cut off the excess material and filled the gaps with a metal paste used for repairwork on cars. Still a bit filling and sanding to do but presentable.
Quick and dirty little Syracus Guide for the Indy 5 backpack.
Quite some time ago I made the Leap of Faith Painting by transfering a printout with waterslide decalfoil on a piece of wood and sealing it after with clear varnish. But I was never truly happy with it nor the wooden back. So I finally modified it.
I painted on top of the foil serveral layers of oilcolors until everything was overpainted. After it was fully dried up I hit it with airbrush (white akrylic color).
The wooden back is now one stained piece, edges sanded and aged with a chisel and a screwdriver. The glow is goldleaf and golden edding.
That texturing is just marvellous, wish I had a piece with this much depth in my collection.
Great work as always Fab
looks very well (y) Good job :)
I did not find time to improve my Leap of Faith Painting yet :rolleyes: .
It needs to get cut a little on each side of the wooden panel and I need to repaint it.
When I tried to use a waterslide decal foil, I wasn't successful with it. I used a normal print on standard paper and glued it to the wood.
I could seal it with different clear coats, so it looks nice now. Around the grail I used gold leaf to make it more authentic.
I hope I can find time to make the changes soon :)
So I was finally able to close this project for me. It was quite a journey starting with a stamp filed out of aluminum which was inverted. (2.1) Then I printing one which actually worked quite well but broke easily and finally ordering one from china I was able to make the Rucksacklabel I'm satisfied with (5.1).
I press the stamp on wet leather with a vice. Then mask off the letters with a template and plasticine, paint and seal it. I tried painting it and then overpaint the letters with white color which I find was a too extreme contrast (4.3).
I've two genuine German WW2 army rucksacks (5.2). One with a natural gray label because the straps are grey and the bag is a darker green. The second one has a painted army green label as the straps are green and the bag has a lighter green color. (5.3)
1.1 All stamps
3.1 3d printed Stamp with thick thread
4.1+2 metal stamp with thin tread not painted
4.3 metal stamp with thin tread fully painted
5.1 metal stamp with thin tread letters not painted
Hello, How I missed that thread???? Congrats for your props, amazing job here! May I ask you a link to the light you used for your CCCP tracing beacon please? I'm trying to make my own so I guess it could help. Thanks in advance.
The second one is what I was looking for : thanks a lot, highly appreciated. I guess/hope this will help others.
Sir, you're talented, helpful and nice.
You are welcome. I replaced the white LED with a blinking red one. It is pretty easy with this lights. So it actually behaves like in the movie.
As my last Ravenwood diary was printed this one is handwritten and drawn with ink and again handbound. Distressing with fuller's earth and leather dressing.
I guess you could call it upcycling
I made a little Satchel for a friends daughter and mine (6) from an old military bag. (16x15x4cm_W/H/D)
The one for my daughter ist double the thickness as she needs to carry a lot of stuff apparently. :lol:
Here is my Marcus Brody Painting from KotCS. The frame is milled, painted, finished with an edge made of gold leaf and then sealed. The picture I made with Gimp and the Remini App.
