Darth Vader reveal mask from ROTJ
First coat of paint, at this stage it looks more like it was intended to be which was a ROTS reveal.
Here it is with the second coat over the black, starting to look more like the ROTJ mask.
Finally getting a start on the greeblies for the inside of the lower jaw, shout out to bonesaredollars for creating the pieces I need for this build.
just wondering if anyone knows the measurements, dimensions of the flat tinned copper wire braid for the inside of the lower jaw, I can easily get some online once I have the correct size???
Breather tubes along with the wires, the wires are 3mm copper with kneedit putty for the ridges covered with shrink wrap.
Thanks Jamesfett, I can't take credit for them, they were created by Bonesaredollars for me, his work creating props is outstanding..
I've put together the tubes for the side walls of the lower jaw using 7mm and 4mm silicone tubing and 3mm red wires. The two small tubes that sit on the bottom are made from 3mm silicone tubing ×2 and 2mm red wires. They all sit on a clear plastic backing.
