Covid19 and lockdown - Lets build a prop together! It's group build time!!!
Very cool! Very James Bond-ish! It would definitely go in the guide under "Equipment" or something (we should probably come up with a table of contents). What did you design this in? Would you be able to export an STL, of the center section and the cartridges separately?
Thanks a lot! It’s designed in Solidworks so, sure I can export the components as stls, no problem.
But it’s just a rough design at the moment so I should perfect the mating surfaces. Also maybe some people would like to use real co2 cartriges so I would need to add a thread. Maybe someone also has a snorkeling mouthpiece and can measure it.
