Breaking Bad Props
Mezco are adding 3 new figures for the end of 2015 also.
attachment.php
Screen used WW Jos A Bank jacket- anyone know which episodes he wore these particular jackets. Will save me looking high and low lol
Steve
Just checked he doesn't wear it in first half of season 5 - jacket has WW #1 on label - will let you know when I match it
Steve
Looks like it was used in scene when he tells Hank to tread lightly - I m very pleased to say the least
Steve
Yes there was a much dirtier version when he is walking through the desert and gets back home. Mine is pretty dirty so guessing was used up until time Hank gets killed - have Sony COA with it but Thx for helping me find where it was used
Steve
I am sure some of this info has already been posted, but I have been piecing through the masks that Walt and Jesse wear throughout the show. There are more masks than this in the show, but I only focused on the models that Jesse and Walt wear and their variations.
Mask: MSA Advantage 1000 Full-Facepiece Respirator 805408 (Med) / 805420 (Large)
Cartridge 1: MSA P100 / CS / CN Cartridge (817588 / 817590)
Cartridge 2: MSA Organic Vapor “Short Stack” Cartridge* (815188) and MSA Cartridge Adapter (809999) * Cartridge has been painted flat black.
Where seen:
  • Ep 101 - Walt wears an unknown sized mask with yellow-tinted lens and CN cartridges while cooking.
  • Ep 101 - Jesse wears a Large mask with yellow-tinted lens and CN cartridges while passed out in RV.
  • Ep 101 - Walter wears a Medium mask with a clear lens and CN cartridges while driving RV.
  • Ep 102 - Indian child finds a Medium mask with a clear lens and CN cartridges at first cook site.
  • Ep 103 - Jesse wears an unknown sized mask with clear lens and CN cartridges at Jesse’s house.
  • Ep 105 - Jesse wears a Medium mask with a clear lens and CN cartridges while cooking.
  • Ep 106 - Walter wears a Medium mask with a clear lens and CN cartridges while cooking.
  • Ep 106 - Hank shows an unknown sized mask with clear lens and CN cartridges to Walter at school.
  • Ep 106 - An unknown sized mask with clear lens and short stack cartridges sitting on school shelf.
  • Ep 107 - Jesse wears a Medium mask with a clear lens and CN cartridges*.
    *Identification stickers on back of cartridges have been blacked out.
  • Ep 107, 201, 204, 209, 303 – Jesse wears a Medium mask with a clear lens and short stack cartridges.
Mask: 3M Dual Cartridge Respirator, Medium (07192)
Goggles: MSA Sightgard IV (vented) Safety Goggles (10106270)
Where seen:
  • Ep 103 - Walt wears mask
  • Ep 105 - Badger wears mask.
Mask: MSA Advantage 3000 Full-Facepiece Respirator (10028995)
Cartridge: MSA Advantage GMA / Organic Vapor Cartridge (815355) and MSA Advantage R95 Prefilter & Cover (815401)
Where seen:
  • Ep 106 – Mask seen on school shelf.
  • Ep 107, 201, 205, 209 - Walt wears mask.
  • Ep 203 – Badger wears mask.
  • Ep 410 – Mike and Gus wear mask with no black prefilter covers in Mexico.
Mask: Survivair Premier Half-Mask Respirator T-Series, Medium (312000)
Cartridge: Survivair T100100 survivair Cartridge and Survivair N95 Filter Retainer(140172)
Where seen: Ep 210 - Walt wears mask.
Note: VERY important that you get the T-series or the filter retainer will not fit.
Mask: 3M Full Facepiece 6800 Respirator
Cartridge 1: 3M 60926 Multi Gas Vapor Cartridge (Walt)
Cartridge 1: 3M 60921 Organic Vapor Cartridge (Jesse)
Where seen:
  • Ep 306, 307, 313 - Gale wears Medium mask, both with 60926 cartridges.
  • Ep 309, 311 – An unknown sized mask seen on superlab table.
  • Ep 310, 311 – Jesse wears Medium mask with 60926 cartridges.
  • Ep 401 – Victor and Mike wear unknown sized masks with 60921 cartridges
  • Ep 306, 307, 311, 313, 401, 404, 405, 407, 409, 413 – Walt wears Large mask with 60926 cartridges.
  • Ep 401, 413 - Jesse wears Medium mask with 60921 cartridges.
Mask: MSA Advantage 4000 Full-Facepiece Respirator, Medium (10083794)
Cartridge: 3M 6001 Organic Vapor Cartridge
Where seen: Ep 410 – Jesse wears mask in Mexico.
Note. This appears to be a forced together assembly as the mask and the cartridge do not match. To get this look you can simply take the "U" clip off the bottom of the inlet on the front of the mask and then hold the filter in place while pouring hot glue through the inlet and exhale holes in the mouth-cup from inside the mask. If you use high-temp hot glue this works really well and gives the exact, nearly seamless look as seen on the show.
Mask:
3M Full Facepiece 7800S Respirator Cartridge: 3M 6001 Organic Vapor Cartridge
Special Note: Note the green connector buttons that link the facemask to the headstrap. These masks are also sold with red and yellow buttons, but Walt and Jesse's buttons are green. The color of the buttons are size indicators:
Red = Small
Yellow = Medium
Green = Large
Thanks to @Alive for this info!
Also note that the nose cup assembly has been removed from these masks, revealing more of the actor's face.
Final note: this mask is built to accept 40mm NATO style threaded filters However, the 6001 filters are meant for bayonet type lugs and will not readily go onto a 40mm threaded mask. 3M does make an adapter, specifically for the 7800 mask that is used to allow bayonet type filters to be attached. This adapter is a "3M Cartridge/Filter Adapter 701". The part # is 70070408508. New 7800S masks come with these adapters but if you get a used mask, it may not.T
Where seen:
  • Ep 503 – Jesse and Walt wear masks.
  • Ep 506 – Mike and Walt wears masks, Todd wears mask with yellow connector button with MSA Advantage GMA / Organic Vapor Cartridge (815355).
  • Ep 507 - Todd and Walt wear masks.
  • Ep 508 – Walt wears mask.
  • Ep 513 - Todd wears mask.
Thumbs up to Art for providing great references on the gas masks used within the show!
I myself have started a small gas mask collection of my own haha, but that ended shortly because I focused on other important things.
So I didn't really get to complete my collection, but hopefully I will by the end of this year!
There is something I wanted to point out to everyone before any of you end up buying any MSA Advantage 1000 Respirators.
I am a bit anal when it comes to being precisely on the dot (size, cartridge, strap).
The MSA 1000 gas masks comes in two different versions and 3 different sizes (S, M, L). If you end up getting the medium/large gas mask and want to be on the dot, make sure you got the right version. When I bought my very first gas mask (MSA 1000, Medium), I found out it wasn't the right one because the strap was incorrect. I remember doing some research and there were specific part numbers that provided which one had the "dot" straps.
This is ripped out from MSA's website: http://us.msasafety.com/Air-Purifyi...ull-Facepiece-Respirator/p/000050001700001600
Under Part Numbers, you can see the different sizes:
Medium: 805408
Large: 805420
If you dig deeper, you'll notice that the same gas mask changes its part no.
Again from MSA: http://us.msasafety.com/Air-Purifyi...d-Riot-Control-Gas-Masks/p/000050001700001500
Medium: 813859
Large: 813861
One of these versions has the "dot" straps"
According to Boss Saftey Products, the version that has the "dot" straps are part no. 813859: http://www.bosssafety.com/p-9680-ms...-medium.aspx?gclid=CIazo-axjcQCFY6UfgodoisAzw
Its safe to assume that the gas mask shown is what you'll end up, hopefully with the rights traps too.
Usually I would hit up eBay and just look at the pictures that the sellers were able to provide just to see if it fits my interests.
The other things I wanted to point out were the 3M 7800S Respirators.
"Special Note: Note the green connector buttons that link the face mask to the head strap. These masks are also sold with yellow and red buttons, but Walt and Jesse's buttons are green." - Art
I actually own this gas mask, but ended up being disappointed because I found out I got the wrong size, months after. So I ended up keeping it anyways. I bought a size medium with yellow connectors that held the straps to the mask. The one I should have bought was the one that had the "green" connectors, which turns out to be a size large.
You'll see in the manual how the color of the connectors indicate the size of the mask
Once again Art you did a great job in referencing, I was waiting for someone to actually post the gas masks that Walt and Jesse used throughout the show!
