Bladerunner 2019 and 2049 inspired costumes
My brown leather belt from RLLEATHER UKRAINE arrived. Stunning!
Will get a black belt for my 2049 costume.
Replaced silver Chicago screw with a brass one.
Added my buckle.
Here I have another update. And a bit of an issue. My Magnoli orange blazer is too short in length. Sadly no fix to it. I can’t afford to buy another. Not sure where the measurements got messed up.
Does it look bad? Being that short in length?
I have another blazer from off the shelf. The sleeves are long. I will need to shorten them.
Here are some pics, it’s coming along!
I bought some cheap Adidas trainers for cons. My vintage Adidas are for display.
I also got some cheap grey pants from vinted.
Yep, the jacket is too short. I don't know if it's lined inside, but you could remove the lining and make it a little more "floppy" and longer (not by much). The rest looks good(y)(y)(y)
Gorram! I knew it! Damn that’s unfortunate. Expensive mistake.
Edit: Not a total loss, my wife can use it for her 2019 build. Maybe alter the sides for her a bit. Woman’s blazer is around this length seeing pics on the google.
What you think of the other generic blazer?
The generic blazer is better in length (y)(y) It has the present look for men (the '30s/'40s designs were longer and covering your behind, like the BR blazer that Harrison was wearing);)
Tomenosuke sent out a email, holsters are shipping! Super excited for this holster. This will be my 2019 costume display holster. It’ll be too nice to cosplay with it. I have another for that. :]
Tomen blog said they will make another four this May if you missed out. Pics taken from blog.
I finally had the courage to sand the seams/flash from the Tomenosuke zinc parts.
I had a Teddz steel cylinder that I replaced the CAW plastic one. But later it gave me issues in cycling the steel cylinder. I went back to the original plastic cylinder.
I blued parts and painted some. The bluing didn’t turn out well. But hey! Not half bad. I think I will leave it janky. Add a tiny bit of surface rust later. Give it character. There are many like this, but this one is mine. :]
I’m missing the radio knob. I think I gave it away a while back thinking I had a spare. Hahah! I don’t.
What do we think of the grips? Do they need to be polished to be see through? Idk how to polish resin.
It looks better in a person. I can’t stop staring at it.
Here is the Teddz cylinder blued. Unfortunately it doesn’t rotate inside the CAW. The dimensions are slightly off to a Tomenosuke cylinder.
As you can seen a line on the cylinder where it is catching.
I don’t have any primer caps, so in the meantime the steel cylinder stays cozy in the CAW.
I tried to buff the grips and I effed them up lol. Sanded them and they’re even more dull than before. Will try to polish again laterz.
