Unlimited Run Blade Runner - Deckard's Blaster (Version 3)
I'd love to buy the baby Deckard and baby K blaster as a set!! I already have something that could work as a stand for them too! :)
Cool! It's good timing, everything is on sale atm, refer to this thread, PM me if you have any questions
Actually I realize I am totally late for work at the moment and you have other goodies I may want as well so I will place my order this evening. Thanks again rgriesbeck :))
That was a great idea to pair up your 1 to 1 Blaster with Soulinertias Amber Grips. I was wondering if they`d fit your 1 to 1 Blaster. hmmmmm
Well, it looks indeed like I will be taking a swing at the new Version 3 rgriesbeck Bladerunner Blaster. ;p This should be very interesting.
rgriesbeck Deckard Blaster Vers. 2.... with Soulinertia Grip mod. Original Deckard Blaster on left, rgriesbecks Deckard Blaster Vers. 2 on right. ;p Awesome fun doing rgriesbecks Blaster vers. 2.
Got my new rgriesbeck Deckard Vers. 3 Kits last week. Gotta say..... they are Beasts. The Fun begins. ;p Even though prep is
still demanding, with this new 1 to 1 scale Deckard Blaster I can see it`ll be alot more forgiving for those who haven`t prepped out a 3D Print before. ;p When I say demanding, I don`t mean difficult. This Kit seems to be a higher rez than the rgriesbeck Vers. 2. Impressive! It mimics the Tomenosuke partswise. A musthave for any Bladerunner Fan. ;p
only a couple parts actually glued. some screws. big parts pretty much fitted. now to disassemble finish sand , paint and reassemble and wire up. may use one trigger to activate lites. very nice kit
more painting and small parts and lighting to do.
just need to touchup the paint a put some small parts on andwire it up now.
just some wiring and a couple more small parts to go
partially wired. gonna make or find a switch that will turn on lights when mag is inserted
Want to add a bit more authenticity to,your rgriesbeck Vers. 3 Deckard? Go pick yourself up a good round file from your local Hardware Store. Carefully ream off the print lines inside the Tumbler Bullet chambers. Then pop down to your Local Firing Range. They prolly sell 44. Magnum spent casings. Try 1 in a chamber. It should slide in a bit. Then continue carefully reaming equally on the inner circular chamber wall until your 44. Magnum round drops in smoothly. This will take awhile cause you want to take off ONLY what you need to get the 44. Magnum shell to drop in. Lastly, you need to add the 3D printed Bullet Lead ends to your spent casings. There is a trick I use to keep the Lead end leveled and positioned. pm me if you want to know how I did this, if you are having issues. ;p I`ve pre primed mine. Then I mask off the brass 44. Magnum casings, and paint the primered printed Lead ends using Humbrol Metalcote Polished Aluminum. I added a pic to show what rgriesbecks printed Lead end looks like grafted into the real 44. Magnum brass casing. Hope you dig. ;p ;p
I did this with rgriesbecks Vers. 2 Deckard. And it`s a very cool mod. ;p
