DrStranglove
Sr Member
And how long is the MR one?
Try a adhesive solvent called UN-DU. Its a clear fluid just couple of drops and wipe it off. I have have came to many cases like that and it has saved the day. Usually it can be found in stores like Bed, Bath & Beyond or Linens & Things. They also have a website:
Un-Do.com
You should definitely give it a shot, its a great product. Hope it helps.
[/b]
The MR sword is 29"
[/b]
Kevin,I just finished using Novus #2 scratch remover. It's very slightly abrasive and it cleaned off the mark quite handily. As the handle is painted, I used it on the rest of the handle as well so it would match the sheen of the cleaned off area and it looks great. You can actually see more of the braid(?) detail that they were trying for. Still, I should not have had to try this. At least it worked.
Cheers,
Kevin
[/b]
Pathetic.
MR may give you a hassle over replacing it if you try and fix an error that should have never gone out the door.
[/b]
Well, I was slightly underwhelmed with the Narnia sword, but since I like most all MR stuff I ordered the Sparrow sword. #50 out of 3000.
Of course the typical attention MR places on presentation is here in a 30 pound box, but I search for the sword amongs the styrafoam. It's dwarfsized next to the huge framed display panel but I see a blemish on the handle. It's obvious that the painting of the faux grain was wet when placed into the box.
OK, it looks bad but I'm sure the finish is good. I put a little goof off on a rag and gently dap off the styrafoam. well all the pain on the front side of the handle comes off immediately. I'll post pics of that later.
WHY? The quality control CURSE continues
[/b]
I have mine on the way from USA to Spain...
Let's see if mine is ok ... It's a shame this kind of things happen... These pieces are very expensive and there must be NO PROBLEM at all with them...
Now my question is... If I got a damage sword like that... and need a replacement... Who would cover the shipping cost??? (from my home to MR, and from MR to my hoe ?? ) ...
That is a question is killing me ... (everytime I buy something from MR, I dont stop praying until it arrives and see is ok... This shouldnt be this way)
[/b]
