1/6 scale new Xwing project
Okay, so 19x13mm or so. The TinyTV had a pretty bad screen, but the active area you describe. The TinyTV 2 is a little bigger but higher resolution, so if it can fit that's a fairly easy solution. Not much work involved. It doesn't have the greatest off-axis viewing and dark areas glow faintly, like most IPS displays. It does require a press of the power button to power up, though.
I've experimented with the AtomS3 and Lilygo T-QT microcontrollers, which have a pretty small screen. Might be too small for your purposes, though, at 15.2x15.2mm square.
That looks pretty impressive. I will look into it. Thanks
Working on some of the outside paint work.
Some additional pictures from my progress
  • IMG_8034.mov
    64.3 MB
  • IMG_8033.mov
    32.1 MB
I'm building an x-wing in the scale and would like to know if you have measurement's or drawings so that I can build mine. I'd be a great help.
Thanks.
