1/350 Polar Lights Enterprise Refit - Build log
I did a little more modeling in Fusion and knocked out a cargo container. I printed out a batch and I'm happy with how they came out overall. However, as usual, I need to tweak things slightly. I'm happy with how the detail is reading (even though it's tough to see in the unpainted resin), but my original plan was to only print singles and assemble them into larger units. However, I don't like the way they fit together at the seams, so at minimum I think I'm going to do 2x1 and 3x1 assemblies the way the photoetch sets do.
I'll be adding these to my catalog of available prints, so if anyone wants a set, PM me.
I switched resin from Elegoo ABS Like White to Siraya Tech Fast Navy Grey, tweaked the model a bit, and baked in continuous supports around the bottom perimeter and I'm happy with the cargo containers. Now to get some paint on them, do a couple more PE figures, some touch ups,and I'll be ready to close up the shuttle bay.
Love it! Stupid question, but how did you get those horizontal supports beneath the containers? I don't think I've ever seen that.
I modeled them directly in Fusion with the containers themselves. I came up with the idea for a continuous linear support structure when I was trying to get good prints of the replacement engine bells I designed for my 1/72 Eagle Transporter (although I've since seen several people come up with the same idea independently). The thin continuous support eliminates the pucker you often get around support contact points while simultaneously giving a larger contact area.
Here is an early test of one of the engine bells and the support structure for the Eagle. There are three contact areas in this case and some hollowing of the support structure itself to allow resin to drain. In this case the contact areas were still a touch too thick, leading to the rough part line on the inner ring and the chip in the edge of the bell. When you get the size just right, the support and the part separate almost perfectly.
View attachment 1837686 View attachment 1837687
That's brilliant! Too bad I'm lacking those design skills!!
Thats some really nice prints there :D
I must ask how did the light pipes work for the windows?
I had my doubts youll be able to get good 90' bends with printed resin. It works well for straight up guides but not so much for angles.
Thanks! I'm actually getting ready to print a new set since I bought a new Mars 4 Ultra recently to supplement my Saturn for smaller prints that need more detail (the Mars 4 is more than double the XY resolution of the Saturn). This should result in an even smoother, crisper print.
As far as the light pipes go, I haven't done anything since my proof of concept for the saucer rim portholes further upthread, but it works well. I'm definitely going to make some changes and refinements (switching to RGBW instead of RGB is definitely happening), and I may even go with another design using translucent white resin since that worked so well with the turbolift tubes. More experimenting is definitely in order.
Here is the current state of the light pipes:
It's still on my bench. I had a couple of gift builds to do last year, as well as some real life incursions, and I started my 1/48 Macross VF-1S Valkyrie as a change of pace. I'm at the finish line on the Valk, an I plan on getting back to the Enterprise as soon as I'm done.
I thought my build was going smoothly and my details were spot on until I saw how well yours is going and now my confidence in mine is shrinking
Thanks, I appreciate the compliments. I hope you don't get down on your work, I've been building for over 40 years and have pretty insane OCD about this kind of stuff. I looked through your thread, and I think yours is looking great. Your arboretum and custom decals are fantastic, keep it up!
Any progress? Thanks Hoping to see more!
I'm still finishing up my Valkyrie, the oil paint weathering is taking longer than I anticipated and I was also down for a couple of weeks when a plague rat coworker brought Covid into the office. I'm actually thinking of ordering a GreenStrawberry bridge, since I'm not super happy with the HDA one. I also need to decide what to do with the rec deck, I'm not entirely happy with the PE rec deck parts from either the Paragrafix or GS sets. I should have ordered one of the 3D printed ones from Shapeways when that was an option. I may end up modeling and printing my own.
